Datasheet LM4780TA - National Semiconductor Даташит ИС, усилитель, 120 Вт MONO/60W стерео, 4780 — Даташит
Наименование модели: LM4780TA
Купить LM4780TA на РадиоЛоцман.Цены — от 420 до 12 020 ₽15 предложений от 15 поставщиков Микросхема Усилитель звуковой частоты, Audio Amp Speaker 1CH Mono/2CH Stereo 120W/60W Class-AB 27Pin(27+Tab) TO-220 Tube | |||
| LM4780TA/NOPB Texas Instruments | 420 ₽ | ||
| LM4780TA/NOPB Texas Instruments | 900 ₽ | ||
| LM4780TA/NOPB Texas Instruments | по запросу | ||
| LM4780TA National Semiconductor | по запросу | ||
Описание: ИС, усилитель, 120 Вт MONO/60W стерео, 4780
LM4780 OvertureTM Audio Power Amplifier Series Stereo 60W, Mono 120W Audio Power Amplifier with Mute
July 2003
General Description
The LM4780 is a stereo audio amplifier capable of typically delivering 60W per channel of continuous average output power into an 8 load with less than 0.5% THD+N from 20Hz - 20kHz.
The LM4780 is fully protected utilizing National's Self Peak Instantaneous Temperature (°Ke) (SPiKeTM) protection circuitry. SPiKe provides a dynamically optimized Safe Operating Area (SOA). SPiKe protection completely safeguards the LM4780's outputs against over-voltage, under-voltage, overloads, shorts to the supplies or GND, thermal runaway and instantaneous temperature peaks. The advanced protection features of the LM4780 places it in a class above discrete and hybrid amplifiers. Each amplifier of the LM4780 has an independent smooth transition fade-in/out mute. The LM4780
- Количество каналов: 2
- Output Power: 60 Вт
- Диапазон напряжения питания: 20 В ... 84 В
- THD + N: 0.03% @ 30 Вт, 8 Ом, VDD=35V
- Load Impedance: 4 Ом
- Amplifier Case Style: TO-220
- Количество выводов: 27
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: TO-220
- Bandwidth: 8 МГц
- Семейство: 4780
- Маркировка: LM4780TA
- Gain Bandwidth: 8 МГц
- IC Generic Number: 4780
- Input Offset Voltage Max: 10mV
- Load Impedance Min: 4 Ом
- Number of Amplifiers: 2
- Рабочий диапазон температрур: -20°C ... +85°C
- Output Power Pout: 60 Вт @ 8 Ом
- Power Rating RMS: 60 Вт
- Slew Rate: 19 В/мкс
- Supply Voltage + Nom: 84 В
- Способ монтажа: Through Hole
