Datasheet LM4860M - National Semiconductor Даташит усилитель, аудио 1 Вт, SMD, 4860, SOIC16 — Даташит
National Semiconductor LM4860M
Наименование модели: LM4860M
39 предложений от 24 поставщиков
Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS LM4860M Audio Power Amplifier, 1Channel, 1W, 2.7V to 5.5V, SOIC, 16Pins
LM4860M/NOPB
TradeElectronics
LM4860M(SMD)
LM4860M16
727GS
LM4860M/NOPB
Описание: Усилитель, аудио 1 Вт, SMD, 4860, SOIC16
data sheetСкачать Data Sheet
LM4860 1W Audio Power Amplifier with Shutdown Mode
August 2000
LM4860 Series 1W Audio Power Amplifier with Shutdown Mode
General Description
The LM4860 is a bridge-connected audio power amplifier capable of delivering 1W of continuous average power to an 8 load with less than 1% THD+N over the audio spectrum from a 5V power supply.
Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components using surface mount packaging. Since the LM4860 does not require output coupling capacitors, bootstrap capacitors or snubber networks, it is optimally suited for low-power portable systems. The LM4860 features an externally controlled, low-power consumption shutdown mode, as well as an internal thermal shutdown protection mechanism. It also includes two headphone control inputs and a headphone sense output for external monitoring. The unity-gain stable LM4860 can be configured by external gain setting resistors for diff
  • Количество каналов: 1
  • Output Power: 1 Вт
  • Диапазон напряжения питания: 2.7 В ... 5.5 В
  • THD + N: 0.72% @ 1 Вт, VDD=5V
  • Load Impedance: 8 Ом
  • Amplifier Case Style: SOIC
  • Количество выводов: 16
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Amplifier Type: Power
  • Bandwidth: 20 кГц
  • Семейство: 4860
  • IC Generic Number: 4860
  • Load Impedance Min: 8 Ом
  • Количество логических функций: 4860
  • Number of Amplifiers: 1
  • Рабочий диапазон температрур: -20°C ... +85°C
  • Operational Amplifier Features: аудио
  • Output Power Pout: 1.15 Вт @ 8 Ом
  • Power Rating RMS: 1.15 Вт
  • Supply Voltage + Nom: 5 В
  • Способ монтажа: SMD
На английском языке: Datasheet LM4860M - National Semiconductor AMP, AUDIO 1 W, SMD, 4860, SOIC16
