Datasheet LM4864M - National Semiconductor Даташит усилитель, аудио, BOOMER 0.3 Вт, SMD, SOIC8 — Даташит
National Semiconductor LM4864M
Наименование модели: LM4864M
29 предложений от 17 поставщиков
Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS LM4864M/NOPB Audio Power Amplifier, AB, 1Channel, 675mW, 2.7V to 5.5V, SOIC, 8Pins
LM4864M/NOPB
32 ₽
727GS
LM4864M
от 64 ₽
Эиком
LM4864M/NOPB
199 ₽
LM4864M
Описание: Усилитель, аудио, BOOMER 0.3 Вт, SMD, SOIC8
data sheetСкачать Data Sheet
LM4864 725mW Audio Power Amplifier with Shutdown Mode
September 2004
General Description
The LM4864 is a bridged audio power amplifier capable of delivering 725mW of continuous average power into an 8 load with 1% THD+N from a 5V power supply.
Boomer ® audio power amplifiers were designed specifically to provide high quality output power from a low supply voltage while requiring a minimal amount of external components. Since the LM4864 does not require output coupling capacitors, bootstrap capacitors or snubber networks, it is optimally suited for low-power portable applications. The LM4864 features an externally controlled, low power consumption shutdown mode, and thermal shutdown protection. The closed loop response of the unity-gain stable LM4864 can be configured by external gain-setting resistors. The device is available in multiple package types to suit various applications. LM4864M & LM4864N*, 8 load LM4864MM, 8 load (Note
  • Amplifier Class: AB
  • Количество каналов: 1
  • Диапазон напряжения питания: 2.7 В ... 5.5 В
  • THD + N: 0.7% @ 300 мВт, 8 Ом, VDD=5V
  • Load Impedance: 8 Ом
  • Amplifier Case Style: MSOP
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Семейство: 4864
  • Load Impedance Min: 8 Ом
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Output Power Pout: 725 мВт @ 8 Ом
  • Power Rating RMS: 675 мВт
  • Способ монтажа: SMD
На английском языке: Datasheet LM4864M - National Semiconductor AMP, AUDIO, BOOMER 0.3 W, SMD, SOIC8
