Заказные клавиатуры Accord по вашему ТЗ
Datasheet LM4865M - National Semiconductor Даташит усилитель, AUDIO/VOLT CONTROL 0.75 Вт, 4865 — Даташит
National Semiconductor LM4865M
Наименование модели: LM4865M
Описание: Усилитель, AUDIO/VOLT CONTROL 0.75 Вт, 4865
data sheetСкачать Data Sheet
LM4865 750 mW Audio Power Amplifier with DC Volume Control and Headphone Switch
October 2002
General Description
The LM4865 is a mono bridged audio power amplifier with DC voltage volume control.
The LM4865 is capable of delivering 750mW of continuous average power into an 8 load with less than 1% THD when powered by a 5V power supply. Switching between bridged speaker mode and headphone (single ended) mode is accomplished using the headphone sense pin. To conserve power in portable applications, the LM4865's micropower shutdown mode (IQ = 0.7µA, typ) is activated when less than 300mV is applied to the DC Vol/SD pin. Boomer audio power amplifiers are designed specifically to provide high power audio output while maintaining high fidelity. They require few external components and operate on low supply voltages. n Other portable audio devices
  • Количество каналов: 1
  • Output Power: 750 мВт
  • Диапазон напряжения питания: 2.7 В ... 5.5 В
  • THD + N: 0.6% @ 8 Ом, VDD=5V
  • Load Impedance: 8 Ом
  • Amplifier Case Style: MSOP
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Amplifier Type: Power
  • Семейство: 4865
  • Маркировка: LM4865M
  • IC Generic Number: 4865
  • Input Offset Voltage Max: 50mV
  • Load Impedance Min: 8 Ом
  • Количество логических функций: 4865
  • Number of Amplifiers: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Operational Amplifier Features: Headphone switch
  • Output Power Pout: 750 мВт @ 8 Ом
  • Power Rating RMS: 750 мВт
  • Supply Voltage + Nom: 5 В
  • Способ монтажа: SMD
На английском языке: Datasheet LM4865M - National Semiconductor AMP, AUDIO/VOLT CONTROL 0.75 W, 4865
Политика конфиденциальности
