Datasheet LM4871MM/NOPB - National Semiconductor Даташит ИС, усилитель аудио PWR W/SHUTDWN 8MSOP — Даташит
Наименование модели: LM4871MM/NOPB
![]() 47 предложений от 18 поставщиков Микросхема Усилитель звуковой частоты, Audio Power Amplifier, AB, 1Channel, 3W, 2V to 5.5V, MSOP, 8Pins | |||
LM4871MM/NOPB Texas Instruments | от 8.81 ₽ | ||
LM4871MM/NOPB Texas Instruments | 133 ₽ | ||
LM4871MM/NOPB Texas Instruments | от 396 ₽ | ||
LM4871MM/NOPB National Semiconductor | по запросу |
Описание: ИС, усилитель аудио PWR W/SHUTDWN 8MSOP
LM4871 3W Audio Power Amplifier with Shutdown Mode
January 2003
General Description
The LM4871 is a mono bridged audio power amplifier capable of delivering 3W of continuous average power into a 3 load with less than 10% THD when powered by a 5V power supply (Note 1).
To conserve power in portable applications, the LM4871's micropower shutdown mode (IQ = 0.6µA, typ) is activated when VDD is applied to the SHUTDOWN pin. Boomer audio power amplifiers are designed specifically to provide high power, high fidelity audio output. They require few external components and operate on low supply voltages from 2.0V to 5.5V. Since the LM4871 does not require output coupling capacitors, bootstrap capacitors, or snubber networks, it is ideally suited for low-power portable systems that require minimum volume and weight. Additional LM4871 features include thermal shutdown protection, unity-gain stability, and external gain set.
- Класс усилителя: AB
- Количество каналов: 1
- Выходная мощность: 3 Вт
- Диапазон напряжения питания: 2 В ... 5.5 В
- THD + N: 0.25% @ 1 Вт, 8 Ом, VDD=5V
- Load Impedance: 3 Ом
- Рабочий диапазон температрур: -40°C ... +85°C
- Тип корпуса: MSOP
- Количество выводов: 8
- SVHC: No SVHC (19-Dec-2011)
- Семейство: 4871
- Входной импеданс минимальный: 8 Ом
- Средневзвешенная мощность номинальная: 1.5 Вт
- Способ монтажа: SMD
