Datasheet LM4875MM - National Semiconductor Даташит ИС, усилитель, аудио, 1 Вт, моно, 8MSOP — Даташит
Наименование модели: LM4875MM
![]() 29 предложений от 17 поставщиков Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS LM4875MM/NOPB Audio Power Amplifier, 1Channel, 750mW, 2.7V to 5.5V, MSOP, 8Pins | |||
LM4875MM/NOPB Texas Instruments | 56 ₽ | ||
LM4875MM/NOPB Texas Instruments | от 70 ₽ | ||
LM4875MM/NOPB National Semiconductor | 202 ₽ | ||
LM4875MM Texas Instruments | по запросу |
Описание: ИС, усилитель, аудио, 1 Вт, моно, 8MSOP
LM4875 750 mW Audio Power Amplifier with DC Volume Control and Headphone Switch
January 2002
General Description
The LM4875 is a mono bridged audio power amplifier with DC voltage volume control.
The LM4875 is capable of delivering 750mW of continuous average power into an 8 load with less than 1% THD when powered by a 5V power supply. Switching between bridged speaker mode and headphone (single ended) mode is accomplished using the headphone sense pin. To conserve power in portable applications, the LM4875's micropower shutdown mode (IQ = 0.7µA, typ) is activated when less than 300mV is applied to the DC Vol/SD pin. Boomer audio power amplifiers are designed specifically to provide high power audio output while maintaining high fidelity. They require few external components and operate on low supply voltages.
- Количество каналов: 1
- Выходная мощность: 750 мВт
- Диапазон напряжения питания: 2.7 В ... 5.5 В
- THD + N: 0.6% @ 300 мВт, 8 Ом, VDD=5V
- Load Impedance: 8 Ом
- Рабочий диапазон температрур: -40°C ... +85°C
- Тип корпуса: MSOP
- Количество выводов: 8
- SVHC: No SVHC (19-Dec-2011)
- Семейство: 4875
