Datasheet LM4880M - National Semiconductor Даташит усилитель, аудио DUAL 0.25 Вт, 4880, SOIC8 — Даташит
Наименование модели: LM4880M
![]() 43 предложений от 26 поставщиков Усилитель звуковой мощности, 250 мВт, AB, 2 канала, 2.7В до 5.5В, SOIC, 8 вывод(-ов) | |||
LM4880M/NOPB Texas Instruments | 43 ₽ | ||
LM4880M/NOPB Texas Instruments | 89 ₽ | ||
LM4880M SO8 микросхема | 540 ₽ | ||
LM4880M, Texas Instruments | по запросу |
Описание: Усилитель, аудио DUAL 0.25 Вт, 4880, SOIC8
LM4880 Boomer Audio Power Amplifier Series Dual 250 mW Audio Power Amplifier with Shutdown Mode
September 2004
LM4880 Dual 250 mW Audio Power Amplifier with Shutdown Mode
General Description
The LM4880 is a dual audio power amplifier capable of delivering typically 250mW per channel of continuous average power to an 8 load with 0.1% THD+N using a 5V power supply.
Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components using surface mount packaging. Since the LM4880 does not require bootstrap capacitors or snubber networks, it is optimally suited for low-power portable systems. The LM4880 features an externally controlled, low-power consumption shutdown mode, as well as an internal thermal shutdown protection mechanism. The unity-gain stable LM4880 can be configured by external gain-setting resistors. n THD+N at 1kHz at 85mW continuous average output power into 32: 0.1% (typ) n Output power at 10% THD+N
- Количество каналов: 2
- Output Power: 250 мВт
- Диапазон напряжения питания: 2.7 В ... 5.5 В
- THD + N: 0.03% @ 200 мВт, 8 Ом, VDD=5V
- Load Impedance: 8 Ом
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Amplifier Type: Power
- Bandwidth: 0.02 МГц
- Семейство: 4880
- IC Generic Number: 4880
- Load Impedance Min: 8 Ом
- Количество логических функций: 4880
- Number of Amplifiers: 2
- Рабочий диапазон температрур: -40°C ... +85°C
- Operational Amplifier Features: аудио
- Output Power Pout: 325 мВт @ 8 Ом
- Power Rating RMS: 325 мВт
- Supply Voltage + Nom: 5 В
- Способ монтажа: SMD
