Datasheet LM4889MA - National Semiconductor Даташит усилитель, аудио, BOOMER 1 Вт, SMD, SOIC8 — Даташит
Наименование модели: LM4889MA
Описание: Усилитель, аудио, BOOMER 1 Вт, SMD, SOIC8
LM4889 1 Watt Audio Power Amplifier
November 2006
General Description
The LM4889 is an audio power amplifier primarily designed for demanding applications in mobile phones and other portable communication device applications.
It is capable of delivering 1 watt of continuous average power to an 8 BTL load with less than 2% distortion (THD+N) from a 5VDC power supply. Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. The LM4889 does not require output coupling capacitors or bootstrap capacitors, and therefore is ideally suited for mobile phone and other low voltage applications where minimal power consumption is a primary requirement. The LM4889 features a low-power consumption shutdown mode, which is achieved by driving the shutdown pin with a logic low. Additionally, the LM4889 features an internal thermal shutdown protection mechanism. The LM4889 contains adv
- Количество каналов: 1
- Диапазон напряжения питания: 2.2 В ... 5.5 В
- THD + N: 0.1% @ 400 мВт, VDD=5V
- Load Impedance: 8 Ом
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Семейство: 4889
- Load Impedance Min: 8 Ом
- Рабочий диапазон температрур: -40°C ... +85°C
- Output Power Pout: 1 Вт @ 8 Ом
- Power Rating RMS: 1 Вт
- Способ монтажа: SMD
