Datasheet LM4889MM - National Semiconductor Даташит ИС, усилитель, аудио мощность 1 Вт, SMD, 8MSOP — Даташит
Наименование модели: LM4889MM
Купить LM4889MM на РадиоЛоцман.Цены — от 33 до 195 ₽31 предложений от 22 поставщиков Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS LM4889MM/NOPB Audio Power Amplifier, AB, 1Channel, 1W, 2.2V to 5.5V, MSOP, 8Pins | |||
| LM4889MM/NOPB National Semiconductor | 43 ₽ | ||
| LM4889MM/NOPB Texas Instruments | от 119 ₽ | ||
| LM4889MM/NOPB Texas Instruments | от 195 ₽ | ||
| LM4889MM/NOPB Texas Instruments | по запросу | ||
Описание: ИС, усилитель, аудио мощность 1 Вт, SMD, 8MSOP
LM4889 1 Watt Audio Power Amplifier
November 2006
General Description
The LM4889 is an audio power amplifier primarily designed for demanding applications in mobile phones and other portable communication device applications.
It is capable of delivering 1 watt of continuous average power to an 8 BTL load with less than 2% distortion (THD+N) from a 5VDC power supply. Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. The LM4889 does not require output coupling capacitors or bootstrap capacitors, and therefore is ideally suited for mobile phone and other low voltage applications where minimal power consumption is a primary requirement. The LM4889 features a low-power consumption shutdown mode, which is achieved by driving the shutdown pin with a logic low. Additionally, the LM4889 features an internal thermal shutdown protection mechanism. The LM4889 contains adv
- Load Impedance: 8 Ом
- THD + N: 0.1% @ 400 мВт, VDD=5V
- Входной импеданс минимальный: 8 Ом
- Выходная мощность: 1 Вт @ 8 Ом
- Диапазон напряжения питания: 2.2 В ... 5.5 В
- Количество выводов: 8
- Количество каналов: 1
- Количество усилителей: 2
- Напряжение питания (+) номинальное: 6 В
- Рабочий диапазон температрур: -40°C ... +85°C
- Семейство: 4889
- Способ монтажа: SMD
- Средневзвешенная мощность номинальная: 1.1 Вт
- Тип корпуса: MSOP
- Тип усилителя: Power
- RoHS: да
- SVHC: No SVHC (19-Dec-2011)
