Datasheet LM4890M/NOPB - National Semiconductor Даташит ИС, усилитель аудио PWR 1 Вт 8-SO — Даташит
Наименование модели: LM4890M/NOPB
|  Купить LM4890M/NOPB на РадиоЛоцман.Цены — от 35 до 376 ₽ 31 предложений от 17 поставщиков Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS LM4890M/NOPB Audio Power Amplifier, AB, 1Channel, 1W, 2.2V to 5.5V, SOIC, 8Pins | |||
| LM4890M/NOPB Texas Instruments | от 376 ₽ | ||
| LM4890M/NOPB National Semiconductor | по запросу | ||
| LM4890M/NOPB Texas Instruments | по запросу | ||
Описание: ИС, усилитель аудио PWR 1 Вт 8-SO
LM4890 1 Watt Audio Power Amplifier
July 2006
General Description
The LM4890 is an audio power amplifier primarily designed for demanding applications in mobile phones and other portable communication device applications.
It is capable of delivering 1 watt of continuous average power to an 8 BTL load with less than 1% distortion (THD+N) from a 5VDC power supply. Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. The LM4890 does not require output coupling capacitors or bootstrap capacitors, and therefore is ideally suited for mobile phone and other low voltage applications where minimal power consumption is a primary requirement. The LM4890 features a low-power consumption shutdown mode, which is achieved by driving the shutdown pin with logic low. Additionally, the LM4890 features an internal thermal shutdown protection mechanism. The LM4890 contains advanced
- Amplifier Class: AB
- Количество каналов: 1
- Output Power: 1 Вт
- Диапазон напряжения питания: 2.2 В ... 5.5 В
- THD + N: 0.1% @ 400 мВт, VDD=5V
- Load Impedance: 8 Ом
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Семейство: 4890
- Load Impedance Min: 8 Ом
- Рабочий диапазон температрур: -40°C ... +85°C
- Output Power Pout: 1 Вт
- Power Rating RMS: 1 Вт
- Способ монтажа: SMD
 Скачать Data Sheet
Скачать Data Sheet
