Datasheet LM4890MM/NOPB - National Semiconductor Даташит ИС, усилитель аудио PWR 1 Вт 8-MSOP — Даташит
National Semiconductor LM4890MM/NOPB
Наименование модели: LM4890MM/NOPB
Описание: ИС, усилитель аудио PWR 1 Вт 8-MSOP
data sheetСкачать Data Sheet
LM4890 1 Watt Audio Power Amplifier
July 2006
General Description
The LM4890 is an audio power amplifier primarily designed for demanding applications in mobile phones and other portable communication device applications.
It is capable of delivering 1 watt of continuous average power to an 8 BTL load with less than 1% distortion (THD+N) from a 5VDC power supply. Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. The LM4890 does not require output coupling capacitors or bootstrap capacitors, and therefore is ideally suited for mobile phone and other low voltage applications where minimal power consumption is a primary requirement. The LM4890 features a low-power consumption shutdown mode, which is achieved by driving the shutdown pin with logic low. Additionally, the LM4890 features an internal thermal shutdown protection mechanism. The LM4890 contains advanced
  • Класс усилителя: AB
  • Количество каналов: 1
  • Выходная мощность: 1 Вт
  • Диапазон напряжения питания: 2.2 В ... 5.5 В
  • THD + N: 0.1% @ 400 мВт, VDD=5V
  • Load Impedance: 8 Ом
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Тип корпуса: MSOP
  • Количество выводов: 8
  • SVHC: No SVHC (19-Dec-2011)
  • Семейство: 4890
  • Входной импеданс минимальный: 8 Ом
  • Средневзвешенная мощность номинальная: 1 Вт
  • Способ монтажа: SMD
На английском языке: Datasheet LM4890MM/NOPB - National Semiconductor IC, AMP AUDIO PWR 1 W 8-MSOP
Политика конфиденциальности
