Datasheet LM4950TS - National Semiconductor Даташит усилитель, 3 Вт STEREO/6W MONO, SMD, 4950 — Даташит
National Semiconductor LM4950TS
Наименование модели: LM4950TS
39 предложений от 19 поставщиков
Микросхема Усилитель звуковой частоты, Audio Power Amplifier, AB, 2Channel, 3.1W, 9.6V to 16V, TO-263, 9Pins
LM4950TS/NOPB
от 37 ₽
LM4950TS/NOPB
161 ₽
LM4950TS/NOPB
169 ₽
LM4950TS
Описание: Усилитель, 3 Вт STEREO/6W MONO, SMD, 4950
data sheetСкачать Data Sheet
LM4950 7.5W Mono-BTL or 3.1W Stereo Audio Power Amplifier
August 2004
General Description
The LM4950 is a dual audio power amplifier primarily designed for demanding applications in flat panel monitors and TV's.
It is capable of delivering 3.1 watts per channel to a 4 single-ended load with less than 1% THD+N or 7.5 watts mono BTL to an 8 load, with less than 10% THD+N from a 12VDC power supply. Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. The LM4950 does not require bootstrap capacitors or snubber circuits. Therefore, it is ideally suited for display applications requiring high power and minimal size. The LM4950 features a low-power consumption active-low shutdown mode. Additionally, the LM4950 features an internal thermal shutdown protection mechanism along with short circuit protection. The LM4950 contains advanced pop & click cir
  • Количество каналов: 2
  • Output Power: 7.5 Вт
  • Диапазон напряжения питания: 9.6 В ... 16 В
  • THD + N: 0.05% @ 2.5 Вт, 4 Ом, VDD=12V
  • Load Impedance: 4 Ом
  • Amplifier Case Style: TO-263
  • Количество выводов: 9
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: TO-263 (D2-Pak)
  • Amplifier Type: Power
  • Bandwidth: 20 кГц
  • Семейство: 4950
  • IC Generic Number: 4950
  • Load Impedance Min: 4 Ом
  • Number of Amplifiers: 2
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Output Power Pout: 3.1 Вт @ 4 Ом
  • Power Rating RMS: 7.5 Вт
  • Supply Voltage + Nom: 16 В
  • Способ монтажа: SMD
Дополнительные аксессуары:
  • Fischer Elektronik - WLPG 02
На английском языке: Datasheet LM4950TS - National Semiconductor AMP, 3 W STEREO/6W MONO, SMD, 4950
