Datasheet LM4951SD - National Semiconductor Даташит Усилитель, FOR CERAMSPEAKER, мини SOIC8 — Даташит
Наименование модели: LM4951SD
Описание: Усилитель, FOR CERAMSPEAKER, мини SOIC8
LM4951 Wide Voltage Range 1.8 Watt Audio Amplifier
General Description
The LM4951 is an audio power amplifier primarily designed for demanding applications in Portable Handheld devices.
It is capable of delivering 1.8W mono BTL to an 8 load, continuous average power, with less than 1% distortion (THD+N) from a 7.5VDC power supply. Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. The LM4951 does not require bootstrap capacitors, or snubber circuits. The LM4951 features a low-power consumption active-low shutdown mode. Additionally, the LM4951 features an internal thermal shutdown protection mechanism. The LM4951 contains advanced pop & click circuitry that eliminates noises which would otherwise occur during turn-on and turn-off transitions. The LM4951 is unity-gain stable and can be configured by external gain-setting resistors.
March 18, 2009
- Количество каналов: 1
- Выходная мощность: 1.8 Вт
- Диапазон напряжения питания: 2.7 В ... 9 В
- THD + N: 0.07% @ 600 мВт, VDD=7.5V
- Load Impedance: 8 Ом
- Рабочий диапазон температрур: -40°C ... +85°C
- Тип корпуса: LLP
- Количество выводов: 10
- SVHC: No SVHC (19-Dec-2011)
- Тип усилителя: Power
- Семейство: 4951
- Входной импеданс минимальный: 8 Ом
- Количество усилителей: 2
- Выходная мощность: 1.8 Вт @ 8 Ом
- Средневзвешенная мощность номинальная: 1.8 Вт
- Напряжение питания (+) номинальное: 9.5 В
- Способ монтажа: SMD
