Datasheet LME49710MA/NOPB - National Semiconductor Даташит аудио усилитель, MONO, CLASS AB, POWERWISE — Даташит
National Semiconductor LME49710MA/NOPB
Наименование модели: LME49710MA/NOPB
13 предложений от 12 поставщиков
Микросхема Буферный усилитель, High Performance, High Fidelity Audio Operational Amplifier 8-SOIC -40℃ to 85℃
LME49710MA/NOPB
228 ₽
727GS
LME49710MA/NOPB
от 258 ₽
LME49710MA/NOPB
LME49710MA/NOPB
Описание: Аудио усилитель, MONO, CLASS AB, POWERWISE
data sheetСкачать Data Sheet
LME49710 High Performance, High Fidelity Audio Operational Amplifier
March 2007
General Description
The LME49710 is part of the ultra-low distortion, low noise, high slew rate operational amplifier series optimized and fully specified for high performance, high fidelity applications.
Combining advanced leading-edge process technology with state-of-the-art circuit design, the LME49710 audio operational amplifiers deliver superior audio signal amplification for outstanding audio performance. The LME49710 combines extremely low voltage noise density (2.5nV/Hz) with vanishingly low THD+N (0.00003%) to easily satisfy the most demanding audio applications. To ensure that the most challenging loads are driven without compromise, the LME49710 has a high slew rate of ±20V/s and an output current capability of ±26mA. Further, dynamic range is maximized by an output stage that drives 2k loads to within 1V of either power suppl
Данные для моделированияДанные для моделирования
  • Amplifier Class: AB
  • Количество каналов: 1
  • Диапазон напряжения питания: ± 2.5 В ... ± 17 В
  • THD + N: 0.00003% @ 2 кОм, VS=± 15 В
  • Load Impedance: 2 кОм
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Семейство: 49710
  • Gain Bandwidth: 55 МГц
  • Input Offset Voltage Max: 0.05 мВ
  • Load Impedance Min: 600 Ом
  • Number of Amplifiers: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Output Current + Max: 26 мА
  • Settling Time: 1.2µs
  • Slew Rate: 20 В/мкс
  • Supply Voltage + Nom: 17 В
  • Способ монтажа: SMD
Дополнительные аксессуары:
  • Weller - SD1000
На английском языке: Datasheet LME49710MA/NOPB - National Semiconductor AUDIO AMP, MONO, CLASS AB, POWERWISE
