Datasheet MAX9736BETJ+ - Maxim Даташит ИС, аудио PWR усилитель, CLASS D, 12 Вт, TQFN-32 — Даташит
Maxim MAX9736BETJ+
Наименование модели: MAX9736BETJ+
42 предложений от 21 поставщиков
Микросхема Усилитель звуковой частоты, MAXIM INTEGRATED PRODUCTS MAX9736BETJ+ Audio Power Amplifier, High Power, D, 2Channel, 12W, 8V to 28V, TQFN, 32Pins...
MAX9736BETJ+
Maxim
262 ₽
TradeElectronics
MAX9736BETJ/V+
Maxim
ЗУМ-СМД
MAX9736BETJ+
Maxim
MAX9736BETJ
Maxim
Производитель: Maxim
Описание: ИС, аудио PWR усилитель, CLASS D, 12 Вт, TQFN-32
data sheetСкачать Data Sheet
19-3108; Rev 1; 10/08
KIT ATION EVALU BLE AVAILA
Mono/Stereo High-Power Class D Amplifier MAX9736
General Description
The MAX9736A/B Class D amplifiers provide high-performance, thermally efficient amplifier solutions.
The MAX9736A delivers 2 x 15W into 8 loads, or 1 x 30W into a 4 load. The MAX9736B delivers 2 x 6W into 8 loads or 1 x 12W into a 4 load. These devices are pinfor-pin compatible, allowing a single audio design to work across a broad range of platforms, simplifying design efforts, and reducing PCB inventory. Both devices operate from 8V to 28V and provide a high PSRR, eliminating the need for a regulated power supply. The MAX9736 offers up to 88% efficiency at 12V supply. Pin-selectable modulation schemes select between filterless modulation and classic PWM modulation. Filterless modulation allows the MAX9736 to pass CE EMI limits with 1m cables using only a low-cost ferrite bead and capacitor on each output. Classic PWM modulation is optimized for best audio performanc
  • Load Impedance: 4 Ом
  • Выходная мощность: 12 Вт
  • Диапазон напряжения питания: 8 В ... 28 В
  • Класс усилителя: D
  • Количество каналов: 2
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Тип корпуса: TQFN
  • RoHS: да
На английском языке: Datasheet MAX9736BETJ+ - Maxim IC, AUDIO PWR AMP, CLASS D, 12 W, TQFN-32
