Заказные клавиатуры Accord по вашему ТЗ
Datasheet SSM2380CBZ - Analog Devices Даташит ИС, усилитель, аудио, 16WLCSP — Даташит
Analog Devices SSM2380CBZ
Наименование модели: SSM2380CBZ
Производитель: Analog Devices
Описание: ИС, усилитель, аудио, 16WLCSP
data sheetСкачать Data Sheet
2 Ч 2 W, Filterless, Stereo, Class-D Audio Amplifier with ALC and I2C SSM2380
FEATURES
Filterless, stereo, Class-D amplifier with - modulation 2 W into 4 load and 1.4 W into 8 load at 5.0 V supply with <1% total harmonic distortion plus noise (THD + N) Highly configurable I2C interface for gain adjust, automatic level control (ALC), and ultralow EMI emissions mode MODE pin can disable I2C interface for more traditional stereo amplifier configuration Stereo-to-mono mixer option via I2C control 93% efficiency at 5.0 V, 1.4 W into 8 speaker Signal-to-noise ratio (SNR): >100 dB Single-supply operation from 2.5 V to 5.5 V Ultralow shutdown current: 20 nA Short-circuit and thermal protection Pop-and-click suppression Available in 16-ball, 2.0 mm Ч 2.0 mm WLCSP
The SSM2380 features a high efficiency, low noise modulation scheme that requires no external LC output filters.
The modulation continues to provide high efficiency even at low output power. The SSM2380 operates with 93% efficiency
На английском языке: Datasheet SSM2380CBZ - Analog Devices IC, AMP, AUDIO, 16WLCSP
Политика конфиденциальности
