Datasheet STA515W - STMicroelectronics Даташит усилитель, аудио, POWER, QUAD, POWERSO36 — Даташит
Наименование модели: STA515W
Описание: Усилитель, аудио, POWER, QUAD, POWERSO36
STA515W
40-volt, 3-amp, quad power half bridge
Features
Multipower BCD technology Low input/output pulse width distortion 200 m RdsON complementary DMOS output stage CMOS-compatible logic inputs Thermal protection Thermal warning output Undervoltage protection Short-circuit protection PowerSSO36 package with exposed pad down 4 channels into 4- loads with 10% THD at VCC = 18 V in single-ended configuration.
It can also deliver 20 W + 20 W into 8- loads with 10% THD at VCC = 18 V in BTL configuration or, in single parallel BTL configuration, 40 W into a 8- load with 10% THD at VCC = 26 V. The input pins have a threshold proportional to the voltage on pin VL. The STA515W comes in a 36-pin PowerSSO package with exposed pad down (EPD).
Description
- Количество каналов: 4
- Диапазон напряжения питания: 10 В ... 36 В
- Load Impedance: 8 Ом
- Количество выводов: 36
- Тип корпуса: PowerSO
- Семейство: 515
- Рабочий диапазон температрур: 0°C ... +70°C
- Output Power Pout: 40 Вт
