Datasheet TDA1905 - STMicroelectronics Даташит усилитель, аудио, + MUTE 5 Вт, 1905, DIP16 — Даташит
STMicroelectronics TDA1905
Наименование модели: TDA1905
Описание: Усилитель, аудио, + MUTE 5 Вт, 1905, DIP16
data sheetСкачать Data Sheet
TDA1905
5W AUDIO AMPLIFIER WITH MUTING
DESCRIPTION The TDA1905 is a monolithic integrated circuit in POWERDIP package, intended for use as low frequency power amplifier in a wide range of applications in radio and TV sets: ­ muting facility ­ protection against chip over temperature ­ very low noise ­ high supply voltage rejection ­ low "switch-on" noise ­ voltage range 4V to 30V The TDA 1905 is assembled in a new plastic package, the POWERDIP that offers the same assembly , ease, space and cost saving of a normal dual in-line package but with a power dissipation of up to 6W and a thermal resistance of 15°C/W (junction to pins).
ABSOLUTE MAXIMUM RATINGS
Symbol Vs Io Io Vi Vi V11 Ptot Tstg, Tj Supply voltage Output peak current (non repetitive) Output peak current (repetitive) Input voltage Differential input voltage Muting thresold voltage Power dissipation at Tamb = 80°C Tcase = 60°C Storage and junction temperature Parameter
  • Amplifier Class: AB
  • Количество каналов: 1
  • Output Power: 5 Вт
  • Диапазон напряжения питания: 4 В ... 30 В
  • THD + N: 0.1% @ 1.5 Вт, 4 Ом, VS=9V
  • Load Impedance: 4 Ом
  • Amplifier Case Style: DIP
  • Количество выводов: 16
  • SVHC: No SVHC (18-Jun-2010)
  • Тип корпуса: DIP
  • Amplifier Type: Power
  • Bandwidth: 0.04 МГц
  • Семейство: 1905
  • Маркировка: TDA1905
  • IC Generic Number: 1905
  • Load Impedance Min: 4 Ом
  • Количество логических функций: 1905
  • Number of Amplifiers: 1
  • Рабочий диапазон температрур: -40°C ... +150°C
  • Operational Amplifier Features: аудио
  • Output Power Pout: 5.5 Вт
  • Power Rating RMS: 5.5 Вт
  • Supply Voltage + Nom: 25 В
На английском языке: Datasheet TDA1905 - STMicroelectronics AMP, AUDIO, + MUTE 5 W, 1905, DIP16
Политика конфиденциальности
