Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet TDA2006V - STMicroelectronics Даташит усилитель, аудио, 12 Вт, PENTAWATT5, VERT — Даташит
STMicroelectronics TDA2006V
Наименование модели: TDA2006V
Описание: Усилитель, аудио, 12 Вт, PENTAWATT5, VERT
data sheetСкачать Data Sheet
TDA2006
12W AUDIO AMPLIFIER
DESCRIPTION The TDA2006 is a monolithic integrated circuit in Pentawatt package, intended for use as a low frequency class "AB" amplifier.
At ±12V, d = 10 % typically it provides 12W output power on a 4 load and 8W on a 8 . The TDA2006 provides high output current and has very low harmonic and cross-over distortion. Further the device incorporates an original (and patented) short circuit protection system comprising an arrangement for automatically limiting the dissipated power so as to keep the working point of the output transistors within their safe operating area. A conventional thermal shutdown system is also included. The TDA2006 is pin to pin equivalent to the TDA2030.
PENTAWATT ORDERING NUMBERS : TDA2006V TDA2006H
  • Количество каналов: 1
  • Load Impedance: 8 Ом
  • Amplifier Case Style: Pentawatt
  • Количество выводов: 5
  • Семейство: 2006
  • Рабочий диапазон температрур: -40°C ... +150°C
  • Output Power Pout: 12 Вт
На английском языке: Datasheet TDA2006V - STMicroelectronics AMP, AUDIO, 12 W, PENTAWATT5, VERT
Политика конфиденциальности
