Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet TDA2030V - STMicroelectronics Даташит усилитель, аудио, 14 Вт, 2030, PENTAWATT-5 — Даташит
STMicroelectronics TDA2030V
Наименование модели: TDA2030V
Описание: Усилитель, аудио, 14 Вт, 2030, PENTAWATT-5
data sheetСкачать Data Sheet
TDA2030
14W Hi-Fi AUDIO AMPLIFIER
DESCRIPTION The TDA2030 is a monolithic integrated circuit in Pentawatt® package, intended for use as a low frequency class AB amplifier.
Typically it provides 14W output power (d = 0.5%) at 14V/4; at ± 14V or 28V, the guaranteed output power is 12W on a 4 load and 8W on a 8 (DIN45500). The TDA2030 provides high output current and has very low harmonic and cross-over distortion. Further the device incorporates an original (and patented) short circuit protection system comprising an arrangement for automatically limiting the dissipated power so as to keep the working point of the output transistors within their safe operating area. A conventional thermal shut-down system is also included. ABSOLUTE MAXIMUM RATINGS
Symbol Vs Vi Vi Io Ptot Tstg, Tj Supply voltage Input voltage Differential input voltage Output peak current (internally limited) Power dissipation at Tcase = 90°C Stoprage and junction temperature Parameter
  • Amplifier Class: AB
  • Количество каналов: 1
  • Output Power: 14 Вт
  • Диапазон напряжения питания: ± 6 В ... ± 18 В
  • THD + N: 0.1% @ 8 Вт, 8 Ом, VDD=14V
  • Load Impedance: 4 Ом
  • Amplifier Case Style: TO-220
  • Количество выводов: 5
  • SVHC: No SVHC (18-Jun-2010)
  • Тип корпуса: Pentawatt
  • Amplifier Type: Power
  • Audio Power Amplifier Type: Class AB
  • Bandwidth: 0.14 МГц
  • Семейство: 2030
  • Маркировка: TDA2030V
  • IC Generic Number: 2030
  • Input Offset Voltage Max: 20 мВ
  • Load Impedance Min: 4 Ом
  • Количество логических функций: 2030
  • Number of Amplifiers: 1
  • Рабочий диапазон температрур: -40°C ... +150°C
  • Operational Amplifier Features: Hi-Fi
  • Output Power Pout: 14 Вт
  • Power Rating RMS: 14 Вт
  • Supply Voltage + Nom: 14 В
На английском языке: Datasheet TDA2030V - STMicroelectronics AMP, AUDIO, 14 W, 2030, PENTAWATT-5
Политика конфиденциальности
