Datasheet LM384N/NOPB - National Semiconductor Даташит ИС, аудио PWR усилитель, CLASS AB, 5.5 Вт DIP-14 — Даташит
Наименование модели: LM384N/NOPB
Описание: ИС, аудио PWR усилитель, CLASS AB, 5.5 Вт DIP-14
LM384 5W Audio Power Amplifier
August 2000
General Description
The LM384 is a power audio amplifier for consumer applications.
In order to hold system cost to a minimum, gain is internally fixed at 34 dB. A unique input stage allows ground referenced input signals. The output automatically selfcenters to one-half the supply voltage. The output is short-circuit proof with internal thermal limiting. The package outline is standard dual-in-line. A copper lead frame is used with the center three pins on either side comprising a heat sink. This makes the device easy to use in standard p-c layout. Uses include simple phonograph amplifiers, intercoms, line drivers, teaching machine outputs, alarms, ultrasonic drivers, TV sound systems, AM-FM radio, sound projector systems, etc. See AN-69 for circuit details.
- Amplifier Class: AB
- Количество каналов: 1
- Output Power, Pout: 5.5 Вт
- Диапазон напряжения питания: 12 В ... 26 В
- Load Impedance: 8 Ом
- Рабочий диапазон температрур: 0°C ... +70°C
- Amplifier Case Style: DIP
