Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet LM4766T/NOPB - National Semiconductor Даташит ИС, аудио PWR усилитель CLASS AB 40 Вт TO-220-15 — Даташит
National Semiconductor LM4766T/NOPB
Наименование модели: LM4766T/NOPB
Описание: ИС, аудио PWR усилитель CLASS AB 40 Вт TO-220-15
data sheetСкачать Data Sheet
LM4756 Dual 7W Audio Power Amplifier w/Mute, Standby and Volume Control
September 2003
General Description
The LM4756 is a stereo audio amplifier capable of delivering 7W/channel at 10% distortion into a 4 or 8 load.
The power amp has an internally set gain of 30dB. A 0V­5V DC controlled volume block provides 80dB of attenuation from input to line-out. Line outputs are available after the volume control for signal routing. The amplifier has a smooth transition fade-in/out mute and a power conserving standby function which are controlled through TTL or CMOS logic. Both functions provide over 75dB of attenuation. The LM4756 maintains an excellent Signal-to-Noise ratio of greater than 70dB with a low noise floor less than 2mV. The IC also maintains above 50dB of channel separation. The LM4756 is available in a 15-lead non-isolated plastic package and is designed for use in TV applications requiring single supply ope
  • Amplifier Class: AB
  • Количество каналов: 1
  • Output Power: 40 Вт
  • Диапазон напряжения питания: 20 В ... 60 В
  • Load Impedance: 8 Ом
  • Рабочий диапазон температрур: -20°C ... +85°C
  • Amplifier Case Style: TO-220
На английском языке: Datasheet LM4766T/NOPB - National Semiconductor IC, AUDIO PWR AMP CLASS AB 40 W TO-220-15
Политика конфиденциальности
