Datasheet LM4811MM/NOPB - National Semiconductor Даташит ИС, аудио PWR усилитель CLASS AB 105 мВт MSOP-10 — Даташит
National Semiconductor LM4811MM/NOPB
Наименование модели: LM4811MM/NOPB
Описание: ИС, аудио PWR усилитель CLASS AB 105 мВт MSOP-10
data sheetСкачать Data Sheet
LM4811 Dual 105mW Headphone Amplifier with Digital Volume Control and Shutdown Mode
April 2006
General Description
The LM4811 is a dual audio power amplifier capable of delivering 105mW per channel of continuous average power into a 16 load with 0.1% (THD+N) from a 5V power supply.
Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. Since the LM4811 does not require bootstrap capacitors or snubber networks, it is optimally suited for low-power portable systems. The LM4811 features a digital volume control that sets the amplifier's gain from +12dB to -33dB in 16 discrete steps using a two-wire interface. The unity-gain stable LM4811 also features an externally controlled, active-high, micropower consumption shutdown mode. It also has an internal thermal shutdown protection mechanism.
  • Amplifier Class: AB
  • Количество каналов: 2
  • Output Power: 105 мВт
  • Диапазон напряжения питания: 2 В ... 5.5 В
  • Load Impedance: 16 Ом
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Amplifier Case Style: MSOP
На английском языке: Datasheet LM4811MM/NOPB - National Semiconductor IC, AUDIO PWR AMP CLASS AB 105 mW MSOP-10
Политика конфиденциальности
