Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet LM4861MX/NOPB - National Semiconductor Даташит ИС, аудио PWR усилитель, CLASS AB, 1.1 Вт SOIC-8 — Даташит
National Semiconductor LM4861MX/NOPB
Наименование модели: LM4861MX/NOPB
Описание: ИС, аудио PWR усилитель, CLASS AB, 1.1 Вт SOIC-8
data sheetСкачать Data Sheet
LM4861 1.1W Audio Power Amplifier with Shutdown Mode
February 2003
General Description
The LM4861 is a bridge-connected audio power amplifier capable of delivering 1.1W of continuous average power to an 8 load with 1% THD+N using a 5V power supply.
Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components using surface mount packaging. Since the LM4861 does not require output coupling capacitors, bootstrap capacitors, or snubber networks, it is optimally suited for low-power portable systems. The LM4861 features an externally controlled, low-power consumption shutdown mode, as well as an internal thermal shutdown protection mechanism. The unity-gain stable LM4861 can be configured by external gain-setting resistors for differential gains of up to 10 without the use of external compensation components. Higher gains may be achieved with suitable compensa
  • Amplifier Class: AB
  • Количество каналов: 1
  • Output Power: 1.1 Вт
  • Диапазон напряжения питания: 2 В ... 5.5 В
  • Load Impedance: 8 Ом
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Amplifier Case Style: SOIC
На английском языке: Datasheet LM4861MX/NOPB - National Semiconductor IC, AUDIO PWR AMP, CLASS AB, 1.1 W SOIC-8
Политика конфиденциальности
