Datasheet LM4871MX/NOPB - National Semiconductor Даташит ИС, аудио POWER усилитель, CLASS AB, 3 Вт, SOIC8 — Даташит
National Semiconductor LM4871MX/NOPB
Наименование модели: LM4871MX/NOPB
50 предложений от 20 поставщиков
Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS LM4871MX/NOPB Audio Power Amplifier, AB, 1Channel, 3W, 2V to 5.5V, SOIC, 8Pins
LM4871MX/NOPB
69 ₽
LM4871MX/NOPB
от 46 ₽
ЗУМ-СМД
LM4871MX/NOPB
LM4871MX/NOPB
Описание: ИС, аудио POWER усилитель, CLASS AB, 3 Вт, SOIC8
data sheetСкачать Data Sheet
LM4871 3W Audio Power Amplifier with Shutdown Mode
January 2003
General Description
The LM4871 is a mono bridged audio power amplifier capable of delivering 3W of continuous average power into a 3 load with less than 10% THD when powered by a 5V power supply (Note 1).
To conserve power in portable applications, the LM4871's micropower shutdown mode (IQ = 0.6µA, typ) is activated when VDD is applied to the SHUTDOWN pin. Boomer audio power amplifiers are designed specifically to provide high power, high fidelity audio output. They require few external components and operate on low supply voltages from 2.0V to 5.5V. Since the LM4871 does not require output coupling capacitors, bootstrap capacitors, or snubber networks, it is ideally suited for low-power portable systems that require minimum volume and weight. Additional LM4871 features include thermal shutdown protection, unity-gain stability, and external gain set.
  • Amplifier Class: AB
  • Количество каналов: 1
  • Output Power, Pout: 3 Вт
  • Диапазон напряжения питания: 2 В ... 5.5 В
  • Load Impedance: 3 Ом
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Amplifier Case Style: SOIC
На английском языке: Datasheet LM4871MX/NOPB - National Semiconductor IC, AUDIO POWER AMP, CLASS AB, 3 W, SOIC8
