Datasheet LM4880M/NOPB - National Semiconductor Даташит ИС, аудио PWR усилитель, CLASS AB 250 мВт SOIC-8 — Даташит
National Semiconductor LM4880M/NOPB
Наименование модели: LM4880M/NOPB
Описание: ИС, аудио PWR усилитель, CLASS AB 250 мВт SOIC-8
data sheetСкачать Data Sheet
LM4880 Boomer Audio Power Amplifier Series Dual 250 mW Audio Power Amplifier with Shutdown Mode
September 2004
LM4880 Dual 250 mW Audio Power Amplifier with Shutdown Mode
General Description
The LM4880 is a dual audio power amplifier capable of delivering typically 250mW per channel of continuous average power to an 8 load with 0.1% THD+N using a 5V power supply.
Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components using surface mount packaging. Since the LM4880 does not require bootstrap capacitors or snubber networks, it is optimally suited for low-power portable systems. The LM4880 features an externally controlled, low-power consumption shutdown mode, as well as an internal thermal shutdown protection mechanism. The unity-gain stable LM4880 can be configured by external gain-setting resistors. n THD+N at 1kHz at 85mW continuous average output power into 32: 0.1% (typ) n Output power at 10% THD+N
  • Amplifier Class: AB
  • Количество каналов: 2
  • Output Power: 250 мВт
  • Диапазон напряжения питания: 2.7 В ... 5.5 В
  • Load Impedance: 8 Ом
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Amplifier Case Style: SOIC
На английском языке: Datasheet LM4880M/NOPB - National Semiconductor IC, AUDIO PWR AMP, CLASS AB 250 mW SOIC-8
Политика конфиденциальности
