Datasheet LM4950TS/NOPB - National Semiconductor Даташит ИС, аудио PWR усилитель CLASS AB 3.1 Вт TO-263-9 — Даташит
Наименование модели: LM4950TS/NOPB
| 44 предложений от 19 поставщиков Микросхема Усилитель звуковой частоты, Audio Power Amplifier, AB, 2Channel, 3.1W, 9.6V to 16V, TO-263, 9Pins | |||
| LM4950TS/NOPB Texas Instruments | от 36 ₽ | ||
| LM4950TS/NOPB Texas Instruments | 102 ₽ | ||
| LM4950TS/NOPB Texas Instruments | от 340 ₽ | ||
| LM4950TS/NOPB | по запросу | ||
Описание: ИС, аудио PWR усилитель CLASS AB 3.1 Вт TO-263-9
LM4950 7.5W Mono-BTL or 3.1W Stereo Audio Power Amplifier
August 2004
General Description
The LM4950 is a dual audio power amplifier primarily designed for demanding applications in flat panel monitors and TV's.
It is capable of delivering 3.1 watts per channel to a 4 single-ended load with less than 1% THD+N or 7.5 watts mono BTL to an 8 load, with less than 10% THD+N from a 12VDC power supply. Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. The LM4950 does not require bootstrap capacitors or snubber circuits. Therefore, it is ideally suited for display applications requiring high power and minimal size. The LM4950 features a low-power consumption active-low shutdown mode. Additionally, the LM4950 features an internal thermal shutdown protection mechanism along with short circuit protection. The LM4950 contains advanced pop & click cir
- Amplifier Class: AB
- Количество каналов: 2
- Output Power: 3.1 Вт
- Диапазон напряжения питания: 9.6 В ... 16 В
- Load Impedance: 8 Ом
- Рабочий диапазон температрур: -40°C ... +85°C
- Amplifier Case Style: TO-263
 Скачать Data Sheet
Скачать Data Sheet
