Datasheet SSM2301RMZ-R2 - Analog Devices Даташит ИС, аудио AMPLIFIER, CLASS D, 1.4 Вт MSOP8 — Даташит
Analog Devices SSM2301RMZ-R2
Наименование модели: SSM2301RMZ-R2
Микросхема Усилитель звуковой частоты, ANALOG DEVICES SSM2301RMZ-R2 Audio Power Amplifier, D, 1Channel, 1.4W, 2.5V to 5V, MSOP, 8Pins
SSM2301RMZ-R2
97 ₽
SSM2301RMZ-R2
663 ₽
SSM2301RMZ-R2
Рутоника
SSM2301RMZ-R2
Производитель: Analog Devices
Описание: ИС, аудио AMPLIFIER, CLASS D, 1.4 Вт MSOP8
data sheetСкачать Data Sheet
Filterless High Efficiency Mono 1.4 W Class-D Audio Amplifier SSM2301
FEATURES
Filterless Class-D amplifier with - modulation No sync necessary when using multiple Class-D amplifiers from Analog Devices, Inc.
1.4 W into 8 at 5.0 V supply with less than 1% THD + N 85% efficiency at 5.0 V, 1.4 W into 8 speaker Greater than 98 dB SNR (signal-to-noise ratio) Single-supply operation from 2.5 V to 5.0 V 20 nA ultralow shutdown current Short-circuit and thermal protection Available in 8-lead, 3 mm Ч 3 mm LFCSP and MSOP packages Pop-and-click suppression Built-in resistors reduce board component count Fixed and user-adjustable gain configurations
The SSM2301 operates with 85% efficiency at 1.4 W into 8 from a 5.0 V supply and has a signal-to-noise ratio (SNR) that is greater than 98 dB. Spread-spectrum modulation is used to provide lower EMI-radiated emissions compared with other Class-D architectures. The SSM2301 has a micropower shutdown mode with a maximum shutdown current of 30 nA. Shu
  • Amplifier Class: D
  • Количество каналов: 1
  • Output Power: 1.4 Вт
  • Диапазон напряжения питания: 2.5 В ... 5 В
  • Load Impedance: 8 Ом
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Amplifier Case Style: MSOP
SSM2301RMZR2, SSM2301RMZ R2
На английском языке: Datasheet SSM2301RMZ-R2 - Analog Devices IC, AUDIO AMPLIFIER, CLASS D, 1.4 W MSOP8
