Datasheet AD1992ACPZ - Analog Devices Даташит ИС, усилитель, аудио, SMD, LFCSP-64, 1992 — Даташит
Наименование модели: AD1992ACPZ
Производитель: Analog Devices
Описание: ИС, усилитель, аудио, SMD, LFCSP-64, 1992
Audio Switching Amplifier AD1992
FEATURES
Integrated stereo modulator and power stage <0.002% THD + N 102 dB dynamic range (A-weighted) 2 Ч 10 W output power (4 , <0.01% THD + N) RDS-ON < 0.3 (per transistor) PSRR > 65 dB On-off-mute pop noise suppression EMI optimized modulator Short-circuit protection Overtemperature protection Low cost DMOS process
GENERAL DESCRIPTION
The AD1992 is a 2-channel, bridge tied load (BTL), switching audio power amplifier with integrated - modulator.
The modulator accepts a single-ended, analog input signal and converts it to a switching waveform to drive speakers directly. A digital, microprocessor-compatible interface provides control of reset, mute, and PGA gain, as well as feedback signals for thermal and overcurrent error conditions. The output stage can operate over a power supply voltages range of 8 V to 20 V. The analog modulator and digital logic operate from a 5 V supply.
- Amplifier Class: D
- Количество каналов: 2
- Output Power: 20 Вт
- Load Impedance: 6 Ом
- Amplifier Case Style: LFCSP
- Количество выводов: 64
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: LFCSP
- Amplifier Type: Power
- Bandwidth: 20 кГц
- Семейство: 1992
- Load Impedance Min: 4 Ом
- Number of Amplifiers: 2
- Рабочий диапазон температрур: -40°C ... +85°C
- Output Power Pout: 10 Вт
- Power Rating RMS: 10 Вт
- Supply Voltage + Nom: 5.5 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 4.5 В ... 5.5 В
