Datasheet LM48510SD - National Semiconductor Даташит усилитель, аудио POWER, CLASS D, LLP-16 — Даташит
Наименование модели: LM48510SD
|  Купить LM48510SD на РадиоЛоцман.Цены — от 37 до 324 ₽ 17 предложений от 17 поставщиков Микросхема Усилитель звуковой частоты, Audio Amp Speaker 1CH Mono 1.9W Class-D 16Pin LLP EP T/R | |||
| LM48510SD/NOPB National Semiconductor | 92 ₽ | ||
| LM48510SD/NOPB National Semiconductor | 296 ₽ | ||
| LM48510SD/NOPB National Semiconductor | 324 ₽ | ||
| LM48510SD/NOPB Texas Instruments | по запросу | ||
Описание: Усилитель, аудио POWER, CLASS D, LLP-16
LM48510 Boosted Class D Audio Power Amplifier
October 2007
General Description
The LM48510 integrates a boost converter with a high efficiency mono, Class D audio power amplifier to provide 1.2W continuous power into an 8 speaker when operating on a 3.3V power supply with boost voltage (PV1) of 5.0V.
When operating on a 3.3V power supply, the LM48510 is capable of driving a 4 speaker load at a continuous average output of 1.7W with less than 1% THD+N. The Class D amplifier is a low noise, filterless PWM architecture that eliminates the output filter, reducing external component count, board area consumption, system cost, and simplifying design. The LM48510's switching regulator is a current-mode boost converter operating at a fixed frequency of 0.6MHz. The LM48510 is designed for use in mobile phones and other portable communication devices. The high (76%) efficiency extends battery life when compared to Boosted Class AB amplifiers. The L
- Количество каналов: 1
- Output Power: 1.2 Вт
- Количество выводов: 16
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: LLP
- Amplifier Type: Power
- Bandwidth: 0.6 МГц
- Семейство: 48510
- Input Offset Voltage Max: 10 мВ
- Load Impedance Min: 4 Ом
- Number of Amplifiers: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- Power Rating RMS: 1.7 Вт
- Supply Voltage + Nom: 6 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 2.7 В ... 5 В
 Скачать Data Sheet
Скачать Data Sheet
