Datasheet LM4864MM - National Semiconductor Даташит усилитель, аудио POWER 300 мВт, MINI SOIC8 — Даташит
Наименование модели: LM4864MM
Описание: Усилитель, аудио POWER 300 мВт, MINI SOIC8
LM4864 725mW Audio Power Amplifier with Shutdown Mode
September 2004
General Description
The LM4864 is a bridged audio power amplifier capable of delivering 725mW of continuous average power into an 8 load with 1% THD+N from a 5V power supply.
Boomer ® audio power amplifiers were designed specifically to provide high quality output power from a low supply voltage while requiring a minimal amount of external components. Since the LM4864 does not require output coupling capacitors, bootstrap capacitors or snubber networks, it is optimally suited for low-power portable applications. The LM4864 features an externally controlled, low power consumption shutdown mode, and thermal shutdown protection. The closed loop response of the unity-gain stable LM4864 can be configured by external gain-setting resistors. The device is available in multiple package types to suit various applications. LM4864M & LM4864N*, 8 load LM4864MM, 8 load (Note
- Количество каналов: 1
- Output Power: 300 мВт
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: Mini SOIC
- Amplifier Type: Power
- Семейство: 4864
- Load Impedance Min: 8 Ом
- Number of Amplifiers: 2
- Рабочий диапазон температрур: -40°C ... +85°C
- Power Rating RMS: 300 мВт
- Supply Voltage + Nom: 6 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 2.7 В ... 5.5 В
Дополнительные аксессуары:
- Electrolube - HTS35SL
