Datasheet LM4893MA - National Semiconductor Даташит усилитель, POWER аудио, 1.1 Вт, SMD, SOIC8 — Даташит
National Semiconductor LM4893MA
Наименование модели: LM4893MA
, AMP, POWER AUDIO, 1.1W, SMD, SOIC8; No. of Channels: 1; Operating Temperature Range: -40℃ to +85℃; No. of Pins: 8;...
LM4893MA/NOPB
64 ₽
LM4893MA/NOPB
LM4893MA/NOPB
SUV System
LM4893MA/NOPB
Описание: Усилитель, POWER аудио, 1.1 Вт, SMD, SOIC8
data sheetСкачать Data Sheet
LM4893 1.1 Watt Audio Power Amplifier
August 2004
General Description
The LM4893 is an audio power amplifier primarily designed for demanding applications in mobile phones and other portable communication device applications.
It is capable of delivering 1.1 watt of continuous average power to an 8 BTL load with less than 1% distortion (THD+N) from a 5VDC power supply. Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. The LM4893 does not require output coupling capacitors or bootstrap capacitors, and therefore is ideally suited for lower-power portable applications where minimal space and power consumption are primary requirements. The LM4893 features a low-power consumption global shutdown mode, which is achieved by driving the shutdown pin with logic low. Additionally, the LM4893 features an internal thermal shutdown protection mechanism. The LM4893 contain
  • Количество каналов: 1
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Семейство: 4893
  • Load Impedance Min: 8 Ом
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Power Rating RMS: 1.1 Вт
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 2.2 В ... 5.5 В
На английском языке: Datasheet LM4893MA - National Semiconductor AMP, POWER AUDIO, 1.1 W, SMD, SOIC8
