Datasheet LM4919MM - National Semiconductor Даташит усилитель, стерео H/P 1.5 В 14 мВт, SMD, 4919 — Даташит
Наименование модели: LM4919MM
![]() 10 предложений от 10 поставщиков Микросхема Усилитель звуковой частоты, IC AMP AUDIO MONO/STER AB 10MSOP | |||
LM4919MM/NOPB National Semiconductor | 42 ₽ | ||
LM4919MM | 187 ₽ | ||
LM4919MM/NOPB National Semiconductor | по запросу | ||
LM4919MM | по запросу |
Описание: Усилитель, стерео H/P 1.5 В 14 мВт, SMD, 4919
LM4919 1.5V, Mono 85mW BTL Output, 14mW Stereo Headphone Audio Amplifier
May 2004
General Description
The unity gain stable LM4919 is both a mono-BTL audio power amplifier and a Single Ended (SE) stereo headphone amplifier.
Operating on a single 1.5V supply, the mono BTL mode delivers 85mW into an 8 load at 1% THD+N. In Single Ended stereo headphone mode, the amplifier delivers 14mW per channel into a 16 load at 1% THD+N. With the LM4919 packaged in the MM package, the customer benefits include low profile and small size. This package minimizes PCB area and maximizes output power. The LM4919 features circuitry that reduces output transients ("clicks" and "pops") during device turn-on and turn-off, an externally controlled, low-power consumption, active-low shutdown mode, and thermal shutdown. Boomer audio power amplifiers are designed specifically to use few external components and provide high quality output po
- Количество каналов: 1
- Output Power: 85 мВт
- Количество выводов: 10
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: MSOP
- Amplifier Type: Power
- Семейство: 4919
- IC Generic Number: 4919
- Load Impedance Min: 8 Ом
- Number of Amplifiers: 2
- Рабочий диапазон температрур: -40°C ... +85°C
- Power Rating RMS: 85 мВт
- Slew Rate: 2.5 В/мс
- Supply Voltage + Nom: 3.6 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 0.9 В ... 2.5 В
Дополнительные аксессуары:
- Electrolube - HTS35SL
