Datasheet LM4665MM - National Semiconductor Даташит усилитель, аудио 1 Вт SWITCH, SMD, MSOP10 — Даташит
Наименование модели: LM4665MM
Купить LM4665MM на РадиоЛоцман.Цены — от 65 до 138 ₽11 предложений от 11 поставщиков Микросхема Усилитель звуковой частоты, Audio Amp Speaker 1CH Mono 1.4W Class-AB 10Pin MSOP | |||
| LM4665MM/NOPB Texas Instruments | 65 ₽ | ||
| LM4665MM/NOPB Texas Instruments | по запросу | ||
Описание: Усилитель, аудио 1 Вт SWITCH, SMD, MSOP10
LM4665 Filterless High Efficiency 1W Switching Audio Amplifier
December 2002
General Description
The LM4665 is a fully integrated single-supply high efficiency switching audio amplifier.
It features an innovative modulator that eliminates the LC output filter used with typical switching amplifiers. Eliminating the output filter reduces parts count, simplifies circuit design, and reduces board area. The LM4665 processes analog inputs with a delta-sigma modulation technique that lowers output noise and THD when compared to conventional pulse width modulators. The LM4665 is designed to meet the demands of mobile phones and other portable communication devices. Operating on a single 3V supply, it is capable of driving 8 transducer loads at a continuous average output of 400mW with less than 2%THD+N. The LM4665 has high efficiency with an 8 transducer load compared to a typical Class AB amplifier. With a 3V supply, the IC's ef
- Количество каналов: 1
- Output Power: 1 мВт
- Количество выводов: 10
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: MSOP
- Amplifier Type: аудио
- Семейство: 4665
- Load Impedance Min: 8 Ом
- Number of Amplifiers: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- Power Rating RMS: 1.4 Вт
- Supply Voltage + Nom: 6 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 2.7 В ... 5.5 В
Дополнительные аксессуары:
- Electrolube - HTS35SL
