Datasheet LM4755T/NOPB - National Semiconductor Даташит усилитель, POWER, аудио, 2 CH, CLASS AB — Даташит
Наименование модели: LM4755T/NOPB
|  Купить LM4755T/NOPB на РадиоЛоцман.Цены — от 30 до 68 ₽ 13 предложений от 13 поставщиков Микросхема Усилитель звуковой частоты, Audio Amp Speaker 2CH Stereo 11W Class-AB 9Pin(9+Tab) TO-220 Rail | |||
| LM4755T/NOPB Rochester Electronics | 68 ₽ | ||
| LM4755T/NOPB | по запросу | ||
| LM4755T/NOPB Texas Instruments | по запросу | ||
Описание: Усилитель, POWER, аудио, 2 CH, CLASS AB
LM4755 Stereo 11W Audio Power Amplifier with Mute
May 2002
General Description
The LM4755 is a stereo audio amplifier capable of delivering 11W per channel of continuous average output power to a 4 load or 7W per channel into 8 using a single 24V supply at 10% THD+N.
The internal mute circuit and pre-set gain resistors provide for a very economical design solution. Output power specifications at both 20V and 24V supplies and low external component count offer high value to consumer electronic manufacturers for stereo TV and compact stereo applications. The LM4755 is specifically designed for single supply operation. n PO at 10% THD+N @ 1kHz into 8 bridged TO-263 package at VCC=12V: 5W (typ)
- Amplifier Class: AB
- Количество каналов: 2
- Output Power: 11 Вт
- Диапазон напряжения питания: 9 В ... 32 В
- Load Impedance: 4 Ом
- Amplifier Case Style: TO-220
- Количество выводов: 9
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: TO-220
- Семейство: 4755
- Load Impedance Min: 4 Ом
- Number of Amplifiers: 2
- Рабочий диапазон температрур: -40°C ... +85°C
- Output Power Pout: 11 Вт
- Power Rating RMS: 11 Вт
- Slew Rate: 2V/Microsec
- Supply Voltage + Nom: 40 В
 Скачать Data Sheet
Скачать Data Sheet
