Datasheet LM4802BLQ - National Semiconductor Даташит усилитель, FOR CERAMSPEAKER, SMD, LQFP28 — Даташит
National Semiconductor LM4802BLQ
Наименование модели: LM4802BLQ
15 предложений от 15 поставщиков
IC AMP CLASS AB MONO 28WQFN. Amplifier IC 1-Channel (Mono) Class AB 28-WQFN (5x5). Linear - Amplifiers - Audio
LM4802BLQ
92 ₽
LM4802BLQ/NOPB
134 ₽
Элитан
LM4802BLQ
531 ₽
LM4802BLQ
Описание: Усилитель, FOR CERAMSPEAKER, SMD, LQFP28
data sheetСкачать Data Sheet
Audio Power Amplifier with Boost Converter to Drive Ceramic Speakers
March 2005
LM4802B Audio Power Amplifier with Boost Converter to Drive Ceramic Speakers
General Description
The LM4802B integrates a Boost Converter with an Audio Power Amplifier to drive Ceramic Speakers in portable applications.
When powered by a 3V supply, it is capable of forcing 12Vp-p across a 2µF + 30 bridge-tied-load (BTL) with less than 1% THD+N. Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. The LM4802B does not require bootstrap capacitors, or snubber circuits. Therefore it is ideally suited for portable applications requiring high output voltage and minimal size. The LM4802B features a low-power consumption shutdown mode. Additionally, the LM4802B features an internal thermal shutdown protection mechanism. The LM4802B contains advanced pop & click circuitry that eliminates noises which would otherwise occur durin
  • Количество каналов: 1
  • Количество выводов: 28
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: LQFP
  • Amplifier Type: Power
  • Семейство: 4802
  • Load Impedance Min: 30 Ом
  • Number of Amplifiers: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Supply Voltage + Nom: 3 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 2.7 В ... 5.5 В
Дополнительные аксессуары:
  • Electrolube - HTS35SL
На английском языке: Datasheet LM4802BLQ - National Semiconductor AMP, FOR CERAMSPEAKER, SMD, LQFP28
