Datasheet LM4900MM - National Semiconductor Даташит усилитель, аудио CELLULAR, SMD, LLP-16 — Даташит
National Semiconductor LM4900MM
Наименование модели: LM4900MM
13 предложений от 12 поставщиков
Микросхема Усилитель звуковой частоты, Audio Amp Speaker 1CH Mono 0.675W Class-AB 8Pin MSOP T/R
727GS
LM4900MM/NOPB
от 17 ₽
LM4900MM/NOPB
54 ₽
LM4900MM/NOPB
LM4900MM
Описание: Усилитель, аудио CELLULAR, SMD, LLP-16
data sheetСкачать Data Sheet
LM4900 265mW at 3.3V Supply Audio Power Amplifier with Shutdown Mode
September 2001
General Description
The LM4900 is a bridged audio power amplifier capable of delivering 265mW of continuous average power into an 8 load with 1% THD+N from a 3.3V power supply.
Boomer ® audio power amplifiers were designed specifically to provide high quality output power from a low supply voltage while requiring a minimal amount of external components. Since the LM4900 does not require output coupling capacitors, bootstrap capacitors or snubber networks, it is optimally suited for low-power portable applications. The LM4900 features an externally controlled, low power consumption shutdown mode, and thermal shutdown protection. The closed loop response of the unity-gain stable LM4900 can be configured by external gain-setting resistors.
  • Количество каналов: 1
  • Output Power: 265 мВт
  • Количество выводов: 16
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: LLP
  • Amplifier Type: Power
  • Семейство: 4900
  • Load Impedance Min: 8 Ом
  • Number of Amplifiers: 2
  • Рабочий диапазон температрур: 0°C ... +125°C
  • Power Rating RMS: 675 мВт
  • Supply Voltage + Nom: 6 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 2 В ... 5.5 В
На английском языке: Datasheet LM4900MM - National Semiconductor AMP, AUDIO CELLULAR, SMD, LLP-16
