Datasheet LM4906MM - National Semiconductor Даташит усилитель, аудио POWER 1 Вт аудио усилитель, SMD — Даташит
National Semiconductor LM4906MM
Наименование модели: LM4906MM
34 предложений от 18 поставщиков
Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS LM4906MM/NOPB Audio Power Amplifier, AB, 1Channel, 1W, 2.6V to 5.5V, VSSOP, 8Pins
LM4906MM/NOPB
40 ₽
LM4906MM/NOPB
90 ₽
LM4906MM/NOPB
727GS
LM4906MM
Описание: Усилитель, аудио POWER 1 Вт аудио усилитель, SMD
data sheetСкачать Data Sheet
LM4906 1W, Bypass-Capacitor-less Audio Amplifier with Internal Selectable Gain
January 2005
General Description
The LM4906 is an audio power amplifier primarily designed for demanding applications in mobile phones and other portable communication device applications.
It is capable of delivering 1W of continuous average power to an 8 BTL load with less than 1% distortion (THD+N) from a +5V power supply. The LM4906 is the first National Semiconductor Boomer Power Amplifier that does not require an external PSRR bypass capacitor. The LM4906 also has an internal selectable gain of either 6dB or 12dB. In addition, no output coupling capacitors or bootstrap capacitors are required which makes the LM4906 ideally suited for cell phone and other low voltage portable applications. The LM4906 contains advanced pop and click circuitry that eliminates noise, which would otherwise occur during turn-on and turn-off trans
  • Количество каналов: 1
  • Output Power: 1 Вт
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: MSOP
  • Amplifier Type: Power
  • Семейство: 4906
  • Load Impedance Min: 8 Ом
  • Number of Amplifiers: 2
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Power Rating RMS: 1 Вт
  • Supply Voltage + Nom: 6 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 2.6 В ... 5.5 В
Дополнительные аксессуары:
  • Electrolube - HTS35SL
На английском языке: Datasheet LM4906MM - National Semiconductor AMP, AUDIO POWER 1 W AUDIO AMP, SMD
