Datasheet LMV1032UP-15 - National Semiconductor Даташит усилитель, MICROPHONE, 15 дБ GAIN, SMD, 1014 — Даташит
National Semiconductor LMV1032UP-15
Наименование модели: LMV1032UP-15
37 предложений от 19 поставщиков
Микросхема Усилитель звуковой частоты, Audio Amp Microphone 1CH Mono Class-AB 4Pin DSBGA T/R
LMV1032UP-15/NOPB
108 ₽
LMV1032UP-15/NOPB
от 246 ₽
LMV1032UP-15
SUV System
LMV1032UP-15/NOPB
Описание: Усилитель, MICROPHONE, 15 дБ GAIN, SMD, 1014
data sheetСкачать Data Sheet
LMV1032-06/LMV1032-15/LMV1032-25 Amplifiers for 3 Wire Analog Electret Microphones
February 2004
General Description
The LMV1032 is an audio amplifier series for small form factor electret microphones.
It is designed to replace the JFET preamp currently being used. The LMV1032 series is ideal for extended battery life applications, such as a bluetooth communication link. The addition of a third pin in electret microphones that incorporate the LMV1032 allows for a dramatic reduction in supply current as compared to the JFET equipped electret microphone. Microphone supply current is thus reduced to 60 µA, assuring longer battery life. The LMV1032 series is guaranteed for supply voltages from 1.7V to 5V, and has fixed voltage gains of 6 dB, 15 dB and 25 dB. The LMV1032 series offers low output impedance over the voice bandwidth, excellent power supply rejection (PSRR), and stability over temperature. The
  • Количество каналов: 1
  • Количество выводов: 4
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: BGA
  • Amplifier Type: Power
  • Семейство: 1012
  • IC Generic Number: 1032
  • Number of Amplifiers: 2
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Supply Voltage + Nom: 5 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 1.7 В ... 5 В
LMV1032UP15, LMV1032UP 15
На английском языке: Datasheet LMV1032UP-15 - National Semiconductor AMP, MICROPHONE, 15 dB GAIN, SMD, 1014
