Datasheet Texas Instruments OPA4134UAE4 — Даташит
СерияOPA4134
МодельOPA4134UAE4
Высокопроизводительные операционные усилители звука SoundPlus™ 14-SOIC от -40 до 85
OPAx134 SoundPlusв„ў High Performance Audio Operational Amplifiers datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 28 окт 2015
Pin14
Package TypeD
Package QTY50
МаркировкаOPA4134UA
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Additional FeaturesBurr-Brownв„ў Audio
АрхитектураFET
CMRR(Min)86 дБ
CMRR(Typ)100 дБ
GBW(Typ)8 МГц
Input Bias Current(Max)100 pA
Iq per channel(Max)5 мА
Iq per channel(Typ)4 мА
Количество каналов4
Offset Drift(Typ)2 uV/C
Output Current(Typ)40 мА
Rail-to-RailNo
Slew Rate(Typ)20 V/us
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2 мВ
  • Remove the DC Portion of Signals with the ADS7817
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    Unwanted portions of a signal, such as a DC pedestal, can be difficult to reject in a single supply circuit. A DC pedestal voltage most typically appears at the output of an operational amplifier with a small signal riding on top of it. This pedestal voltage is required in the analog domain to insure that the small signal that contains the pertinent information never falls below the ground potenti
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA4134UAE4
