Datasheet Texas Instruments TPA2013D1YZHR — Даташит
СерияTPA2013D1
МодельTPA2013D1YZHR
Моно-усилитель звука постоянной выходной мощности 2,7 Вт класса D со встроенным повышающим преобразователем (TPA2013) 16-DSBGA от -40 до 85
TPA2013D1 2.7-W Constant Output Power Class-D Audio Amplifier With Integrated Boost Converter datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 31 мар 2016
Pin16
Package TypeYZH
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY3000
МаркировкаBTH
Thickness (мм).48
Pitch (мм).5
Max Height (мм).625
Analog Supply (V)2.3 Max
АрхитектураClass D Boosted
Audio Input TypeAnalog Input
Control InterfaceGPIO
Iq per channel(Typ)16.5 мА
Iq(Max)23 мА
Iq(Typ)16.5 мА
Load(Min)4 ohms
Выходная мощность2.7 W
PSRR95 дБ
Package GroupDSBGA
Pin/Package16DSBGA, 20QFN
Shutdown Current (ISD)0.04 uA
Speaker ChannelsMono Max
THD + N @ 1 kHz1 %
  • Evaluation Modules & Boards: TPA2013D1EVM
    TPA2013D1 Evaluation Module (EVM)
  • TPA2013D1 Boost Converter Component Selection
    PDF, 506 Кб, Файл опубликован: 19 мар 2009
    A common problem in battery-powered systems is the loss of output power as the battery discharges. Output power must be reduced or limited to the level available at minimum battery voltage or distortion becomes unacceptable. It is possible to overcome this problem by using a boost converter, a switching device that boosts battery output to a fixed higher voltage, to power the amplifiers. TI's T
  • TPA2013D1 Boost Converter Component Specification
    PDF, 112 Кб, Файл опубликован: 9 дек 2008
    Loss of output power is a common problem in battery-powered systems as the battery discharges. This problem can be overcome with a boost converter to power the audio power output amplifiers, like the converter and amplifier in the Texas Instruments TPA2013D, a single-chip solution. Passive components used with the converter dramatically affect its operation, so it is necessary to choose these comp
  • Filter-Free Class-D Audio Amplifiers
    PDF, 259 Кб, Файл опубликован: 9 ноя 2009
    Traditional Class-D amplifiers lose efficiency if they do not use output LC filters. Texas Instruments offers many Class-D amplifiers that are designated Filter-Free. This means they do not require an output LC filter to maintain high efficiency. However, in some cases an LC or ferrite bead filter is required for EMC.
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA2013D1 (2)
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
На английском языке: Datasheet Texas Instruments TPA2013D1YZHR
