Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPA2026D2YZHT — Даташит
СерияTPA2026D2
МодельTPA2026D2YZHT
Стереоусилитель звука SmartGain™ класса D мощностью 3,2 Вт/канал с динамическим диапазоном 16-DSBGA от -40 до 85
TPA2026D2 3.2-W/Ch Stereo Class-D Audio Amplifier With Fast Gain Ramp SmartGain Automatic Gain Control and Dynamic Range Compression datasheet
PDF, 1.3 Мб, Версия: B, Файл опубликован: 31 май 2016
Pin16
Package TypeYZH
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY250
CarrierSMALL T&R
МаркировкаNSV
Thickness (мм).48
Pitch (мм).5
Max Height (мм).625
Analog Supply (V)5.5 Min
АрхитектураClass D
Audio Input TypeAnalog Input
Control InterfaceI2C
Iq per channel(Typ)2.25 мА
Iq(Max)5.5 мА
Iq(Typ)4.5 мА
Load(Min)8 ohms
Выходная мощность3.2 W
PSRR80 дБ
Package GroupDSBGA
Pin/Package16DSBGA
Shutdown Current (ISD)0.2 uA
Speaker ChannelsStereo Max
THD + N @ 1 kHz0.1 %
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA2026D2 (2)
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
На английском языке: Datasheet Texas Instruments TPA2026D2YZHT
