Заказные клавиатуры Accord по вашему ТЗ
Datasheet ТI TPA3100D2RGZT — Даташит
СерияTPA3100D2
МодельTPA3100D2RGZT
Datasheet Texas Instruments TPA3100D2RGZT
Стереоусилитель мощности звука класса D, 20 Вт (TPA3100) 48-VQFN от -40 до 85
20W Stereo Class-D Audio Power Amplifier datasheet
PDF, 1.4 Мб, Версия: F, Файл опубликован: 19 авг 2010
  • TPA3100D2 Mono Amplifier Configuration (Rev. A)
    PDF, 117 Кб, Версия: A, Файл опубликован: 16 апр 2007
  • Interfacing External Devices to the TPA310xDx Amplifiers
    PDF, 105 Кб, Файл опубликован: 29 сен 2008
    TPA310xDx Logic Pin Interface
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
На английском языке: Datasheet Texas Instruments TPA3100D2RGZT
Политика конфиденциальности
