Datasheet Texas Instruments TPA3122D2N — Даташит
СерияTPA3122D2
МодельTPA3122D2N
Стереоусилитель мощности звука класса D, 15 Вт с выходами SE (TPA3122), 20-PDIP от -40 до 85
15-W Stereo Class-D Audio Power Amplifier datasheet
PDF, 507 Кб, Версия: A, Файл опубликован: 17 дек 2007
Pin20
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY20
МаркировкаTPA3122D2
Width (мм)6.35
Length (мм)24.33
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Analog Supply (V)30 Min
Audio Input TypeAnalog
Closed/Open LoopClosed
Control InterfaceHardware
Package GroupPDIP
Power Stage Supply(Max)30 В
Power Stage Supply(Min)10 В
Power to Bridge Tied Load(Max)15 W
Speaker Channels2 Max
Supported Bridge Tied Load(Min)8 Ohms
  • Evaluation Modules & Boards: TPA3122D2EVM
    TPA3122D2 Evaluation Module (EVM)
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA3122D2 (1)
  • TPA3122D2N
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
На английском языке: Datasheet Texas Instruments TPA3122D2N
