Datasheet Texas Instruments TPA3123D2PWP — Даташит
СерияTPA3123D2
МодельTPA3123D2PWP
Стереоусилитель мощности звука класса D, 25 Вт с выходами SE (TPA3123) 24-HTSSOP от -40 до 85
25W Stereo Class-D Audio Power Amplifier datasheet
PDF, 956 Кб, Версия: C, Файл опубликован: 19 авг 2010
46 предложений от 19 поставщиков
Микросхема Усилитель звуковой частоты, Audio Power Amplifier, D, 2Channel, 25W, 10V to 30V, HTSSOP, 24Pins
TPA3123D2PWP
187 ₽
TPA3123D2PWP
530 ₽
TPA3123D2PWP
от 906 ₽
TPA3123D2PWP
от 1 327 ₽
Pin24
Package TypePWP
Industry STD TermHTSSOP
Package QTY60
МаркировкаTPA3123D2
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Analog Supply (V)30 Min
Audio Input TypeAnalog
Closed/Open LoopClosed
Control InterfaceHardware
Package GroupHTSSOP
Package Size: mm2:W x L24HTSSOP: 50 mm2: 6.4 x 7.8(HTSSOP) PKG
Power Stage Supply(Max)30 В
Power Stage Supply(Min)10 В
Power to Bridge Tied Load(Max)25 W
Speaker Channels2 Max
Supported Bridge Tied Load(Min)8 Ohms
  • Evaluation Modules & Boards: TPA3123D2EVM
    TPA3123D2 Evaluation Module (EVM)
  • Filter-Free Class-D Audio Amplifiers
    PDF, 259 Кб, Файл опубликован: 9 ноя 2009
    Traditional Class-D amplifiers lose efficiency if they do not use output LC filters. Texas Instruments offers many Class-D amplifiers that are designated Filter-Free. This means they do not require an output LC filter to maintain high efficiency. However, in some cases an LC or ferrite bead filter is required for EMC.
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA3123D2 (4)
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
На английском языке: Datasheet Texas Instruments TPA3123D2PWP
