Datasheet DS25BR440TSQ/NOPB - National Semiconductor Даташит LVDS QUAD, 3.125GBPS, BUF, 40LLP — Даташит
Наименование модели: DS25BR440TSQ/NOPB
![]() 29 предложений от 16 поставщиков Микросхема LVDS, M-LVDS, ECL, CML, TEXAS INSTRUMENTS DS25BR440TSQ/NOPB LVDS Driver, Transmit Pre-Emphasis, LVDS Buffer, 30 ps, 190mA, -40℃, 85℃, 3V | |||
DS25BR440TSQ/NOPB Texas Instruments | 635 ₽ | ||
DS25BR440TSQ/NOPB Texas Instruments | 767 ₽ | ||
DS25BR440TSQ/NOPB National Semiconductor | по запросу | ||
DS25BR440TSQ/NOPB Texas Instruments | по запросу |
Описание: LVDS QUAD, 3.125GBPS, BUF, 40LLP
DS25BR440 3.125 Gbps Quad LVDS Buffer with Pre-Emphasis and Equalization
February 11, 2008
DS25BR440 3.125 Gbps Quad LVDS Buffer with Transmit Pre-Emphasis and Receive Equalization
General Description
The DS25BR440 is a 3.125 Gbps Quad LVDS buffer optimized for high-speed signal routing and repeating over lossy FR-4 printed circuit board backplanes and balanced cables.
Fully differential signal paths ensure exceptional signal integrity and noise immunity. The DS25BR440 features two levels of transmit pre-emphasis (PE) and two levels of receive equalization (EQ). Both of these features compensate for interconnect losses and ultimately maximize noise margin. A loss-of-signal (LOS) circuit monitors each input channel and a unique LOS pin is asserted when no signal is detected at that input Wide input common mode range allows the switch to accept signals with LVDS, CML and LVPECL levels; the output levels are LVDS. A very small package footprint requires a minimal space on the board whil
- Number of Amplifiers: 4
- Диапазон напряжения питания: 3 В ... 3.6 В
- Выходной ток: 4 мА
- Amplifier Case Style: LLP
- Количество выводов: 40
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: LLP
- Amplifier Type: Buffer
- Семейство: 25
- Рабочий диапазон температрур: -40°C ... +85°C
- Output Type: Fully Differential
- Способ монтажа: SMD
