Datasheet HA3-5002-5Z - Intersil Даташит усилитель, BUFFER, WIDEBAND, 5002, DIP8 — Даташит
Intersil HA3-5002-5Z
Наименование модели: HA3-5002-5Z
110MHz, High Slew Rate, High Output Current Buffer | IC BUFFER 1 CIRCUIT 8DIP
HA3-5002-5Z
Intersil
66 ₽
HA3-5002-5Z
Renesas
HA3-5002-5Z (HA3-5002-5Z  )
Intersil
HA3-5002-5Z
Renesas
Производитель: Intersil
Описание: Усилитель, BUFFER, WIDEBAND, 5002, DIP8
data sheetСкачать Data Sheet
HA-5002
Data Sheet August 4, 2005 FN2921.9
The HA-5002 is a monolithic, wideband, high slew rate, high output current, buffer amplifier.
Utilizing the advantages of the Intersil D.I. technologies, the HA-5002 current buffer offers 1300V/µs slew rate with 110MHz of bandwidth. The ±200mA output current capability is enhanced by a 3 output impedance. The monolithic HA-5002 will replace the hybrid LH0002 with corresponding performance increases. These characteristics range from the 3000k input impedance to the increased output voltage swing. Monolithic design technologies have allowed a more precise buffer to be developed with more than an order of magnitude smaller gain error. The HA-5002 will provide many present hybrid users with a higher degree of reliability and at the same time increase overall circuit performance. For the military grade product, refer to the HA-5002/883 datasheet.
  • Number of Amplifiers: 1
  • Gain Bandwidth: 110 МГц
  • Slew Rate: 1300 В/мкс
  • Диапазон напряжения питания: ± 12 В ... ± 15 В
  • Выходной ток: 220 мА
  • Amplifier Output: Single Ended
  • Amplifier Case Style: DIP
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: DIP
  • Amplifier Type: Buffer
  • Полоса частот: 110 МГц
  • Семейство: 3
  • IC Generic Number: 5002
  • Input Offset Voltage Max: 30 мВ
  • Количество логических функций: 5002
  • Рабочий диапазон температрур: 0°C ... +75°C
  • Особенности ОУ: High output current
  • Output Current Max: 220 мА
  • Output Type: Single Ended
  • Напряжение питания номинальное: 15 В
HA350025Z, HA3 5002 5Z
На английском языке: Datasheet HA3-5002-5Z - Intersil AMP, BUFFER, WIDEBAND, 5002, DIP8
