Datasheet HA3-5033-5 - Intersil Даташит ИС, OP-AMP, SINGLE, 8PDIP — Даташит
Наименование модели: HA3-5033-5
![]() 16 предложений от 16 поставщиков 250MHz Video Buffer | IC VIDEO BUFFER 250MHZ 8DIP | |||
HA3-5033-5 Renesas | 571 ₽ | ||
HA3-5033-5 | 1 077 ₽ | ||
HA350335 | по запросу | ||
HA35033-5 | по запросу |
Производитель: Intersil
Описание: ИС, OP-AMP, SINGLE, 8PDIP
HA-5033
Data Sheet February 6, 2006 FN2924.8
250MHz Video Buffer
The HA-5033 is a unity gain monolithic IC designed for any application requiring a fast, wideband buffer.
Featuring a bandwidth of 250MHz and outstanding differential phase/ gain characteristics, this high performance voltage follower is an excellent choice for video circuit design. Other features, which include a minimum slew rate of 1000V/µs and high output drive capability, make the HA-5033 applicable for line driver and high speed data conversion circuits. The high performance of this product is a result of the Intersil Dielectric Isolation process. A major feature of this process is that it produces both PNP and NPN high frequency transistors which makes wide bandwidth designs, such as the HA-5033, practical. Alternative process methods typically produce a lower AC performance.
- Number of Amplifiers: 1
- Gain Bandwidth: 250 МГц
- Slew Rate: 1100 В/мкс
- Диапазон напряжения питания: ± 5 В ... ± 16 В
- Выходной ток: 100 мА
- Amplifier Output: Single Ended
- Amplifier Case Style: DIP
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: 8-DIP
- Рабочий диапазон температрур: 0°C ... +75°C
- Способ монтажа: Through Hole
- Op Amp Type: Wide Bandwidth
Дополнительные аксессуары:
- Multicomp - HT4241007
HA350335, HA3 5033 5
