Datasheet HA9P5002-9 - Intersil Даташит ИС, AMPLIFIER — Даташит
Intersil HA9P5002-9
Наименование модели: HA9P5002-9
44 предложений от 21 поставщиков
HA9P5002-9Z
Renesas
от 284 ₽
Эиком
HA9P5002-9Z
Renesas
от 2 170 ₽
TradeElectronics
HA9P50029
HA9P5002-9VTR
Intersil
Производитель: Intersil
Описание: ИС, AMPLIFIER
data sheetСкачать Data Sheet
HA-5002
Data Sheet March 8, 2006 FN2921.11
110MHz, High Slew Rate, High Output Current Buffer
The HA-5002 is a monolithic, wideband, high slew rate, high output current, buffer amplifier.
Utilizing the advantages of the Intersil D.I. technologies, the HA-5002 current buffer offers 1300V/µs slew rate with 110MHz of bandwidth. The ±200mA output current capability is enhanced by a 3 output impedance. The monolithic HA-5002 will replace the hybrid LH0002 with corresponding performance increases. These characteristics range from the 3000k input impedance to the increased output voltage swing. Monolithic design technologies have allowed a more precise buffer to be developed with more than an order of magnitude smaller gain error. The HA-5002 will provide many present hybrid users with a higher degree of reliability and at the same time increase overall circuit performance. For the military grade product, refer to the HA-5002/883 datasheet.
  • Number of Amplifiers: 1
  • Gain Bandwidth: 110 МГц
  • Slew Rate: 1300 В/мкс
  • Диапазон напряжения питания: ± 12 В ... ± 15 В
  • Выходной ток: 220 мА
  • Amplifier Output: Single Ended
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: 8-SOIC
  • Amplifier Type: Current
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Output Current Max: 220 мА
  • Output Type: Single Ended
  • Способ монтажа: SMD
Дополнительные аксессуары:
  • Electrolube - HTS35SL
HA9P50029, HA9P5002 9
На английском языке: Datasheet HA9P5002-9 - Intersil IC, AMPLIFIER
