Datasheet LMH6559MA - National Semiconductor Даташит BUFFER, 1.75GHZ CLOSED-LOOP, 6559 — Даташит
National Semiconductor LMH6559MA
Наименование модели: LMH6559MA
37 предложений от 18 поставщиков
LMH6559MA
57 ₽
LMH6559MA-TI
87 ₽
LMH6559MA/NOPB
100 ₽
LMH6559MA/NOPB
от 394 ₽
Описание: BUFFER, 1.75GHZ CLOSED-LOOP, 6559
data sheetСкачать Data Sheet
LMH6559 High-Speed, Closed-Loop Buffer
April 2003
General Description
The LMH6559 is a high-speed, closed-loop buffer designed for applications requiring the processing of very high frequency signals.
While offering a small signal bandwidth of 1750MHz, and an ultra high slew rate of 4580V/µs the LMH6559 consumes only 10mA of quiescent current. Total harmonic distortion into a load of 100 at 20MHz is -52dBc. The LMH6559 is configured internally for a loop gain of one. Input resistance is 200k and output resistance is but 1.2. These characteristics make the LMH6559 an ideal choice for the distribution of high frequency signals on printed circuit boards. Differential gain and phase specifications of 0.06% and 0.02° respectively at 3.58MHz make the LMH6559 well suited for the buffering of video signals. The device is fabricated on National's high-speed VIP10 process using National's proven high performance circuit architectures.
Данные для моделированияДанные для моделирования
  • Number of Amplifiers: 1
  • Gain Bandwidth: 1750 МГц
  • Slew Rate: 4580 В/мкс
  • Диапазон напряжения питания: 3 В ... 10 В
  • Выходной ток: 75 мА
  • Amplifier Output: Single Ended
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Amplifier Type: Buffer
  • Полоса частот: 1750 МГц
  • Семейство: 6559
  • IC Generic Number: 6559
  • Input Offset Voltage Max: 20 мВ
  • Количество логических функций: 6559
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Output Current Max: 75 мА
  • Output Type: Single Ended
  • Напряжение питания номинальное: 10 В
  • Способ монтажа: SMD
На английском языке: Datasheet LMH6559MA - National Semiconductor BUFFER, 1.75GHZ CLOSED-LOOP, 6559
